Help, please. 1.27k ohm resistor readings. What I thought was... [resolved]
dmhenley
A channel imbalance based on very low listening levels is something else. My mistake.
The right channel is working, though at a lower level than the left. All instruments that should be centered are left/center. Vocals, for example.
New resistance readings found A6@ 8.20k ohms.
Other readings were within tolerance.
Do I need to replace the 1.27k ohm resistor?
Appreciate your time,
Darren
Your 1.27K resistor is where your 8.2K resistor should be.
dmhenley said:
Wow. Sorry about that. Good grief.
Those little blue resistors are pretty easy to mix up.  If the 8.2K doesn't reach, you can e-mail replacement parts about getting a replacement.
