kscwuzhere
Hey so I have a Bottlehead Crack that was working for a good week or two when all of a sudden the chassis shocked me! I immediately unplugged and flipped it over and made sure that all my connections looked clean and re-tested. This time the chassis didn't shock me but when i tried unplugging the headphones (which were on a gold plated 1/4" adapter), that shocked me. I rechecked all my connections again and decided to do a resistance/voltage check. After successfully testing the resistances I moved on to the voltage check and everything went well until I put the positive lead on terminal 15, where all of a sudden the crack sparked at that terminal and the tubes immediately stopped glowing. The LEDs on terminal A3 and A8 also weren't lit anymore. Upon recollection I may have touched the positive lead to the right power switch terminal (but im not totally sure). What should I do?
