Laudanum said:My top plate gets pretty good and warm but not uncomfortably hot to the touch. That should be a pretty good indication of the air temp within the wood chassis. Or did you need a more specific answer?
Keep in mind, the heat will vary depending on tubes used as well as other factors like room temp and air circulation and probably several other things Im not thinking about.
You've got my attention PaulPaul Joppa said:When and if the high-current Crack mod comes to pass, it will double the heat dissipated under the hood.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
