I have put together a few bottlehead kits no big issues (great stuff!), anyway with my latest build I am having trouble with a Kaiju amplifier build at the c4S build section. Was getting close to finishing it
The D/left side c4S board is working perfectly, IA is at ~ 525V and OA at ~ 296V, adjusting pot set 46 U to 175V. Sweet!
Now the A socket board: initially IA was ~ 525V but OA was at ~ 110V. Found a resistor miswired (R4 B side of board), fixed that, no change.
Checked again, found I had globbed some solder on transistors Q1/Q2 (and some pins were shorted) on A and B side of the board, icky, cleaned that up, reinserted board, now OA measures ~296V (good), but board won't adjust 32U to the right voltage. Currently that voltage only adjust slightly around ~ 95V. Tried swapping tubes between sides, didnt fix the problem. Took the A socket board out again, resoldered all the joints but no change.
Perhaps some of the transistors are damaged? Not sure.
Any suggestions on what to measure or how to proceed? Thanks for your time.
