Hammond Chokes w/ Quickie - Cheap and Worthwhile!
booangler said:
Hi all,
My Hammond 156C chokes ... fit perfectly on the mounting screws for the D cells.
This made a ... dramatic increase in the base response ...
Alan
Thanks for the info! Since my first Quickie is being used for a low pass filter, bass is important! I'll be ordering a pair today.
Thanks also for the mounting tip.
booangler said:
Three cheers to Dr. Toobz for this brilliant modification.
Cheers,
Alan
I can't take any credit for this mod - at least one other member thought of it first on the old forum (I can't remember who, though). I actually was looking to build CCS's for the Quickie and stumbled upon a mention of the Hammond chokes and the possibility of using them to load the plates. In any case, they definitely are worth the money and bring the Quickie to another level!
I'm pretty sure it was DynaSaur (hey, that rhymes).
I'm glad you guys like the mod. I ordered them today. Then I got the Quickie running tonight as a low pass. It is stunning. I was starting to regret ordering the chokes, because I figured the low end couldn't get any better. I hope to post results of the choke upgrade next weekend.
Since I found different post author suggesting the Hammond Chokes, I will simply say this. Who every suggested the idea, it is a great upgrade. I thank you!
Sincerely,
Alan
I'm another happy user of this mod. It is incredibly easy to do (you don't even have to drill any holes!), and it increases gain, bass authority, and increases the amps overall resolution (at least to my ears).
I mounted them as follows:
1. Replace the four #4-3/8" screws holding the D cell battery holders with #4-3/4" screws. Use the existing nut and tighten according the manual.
2. Place 1 small rubber grommet on each screw (poor man's standoff).
3. Place the chokes on the screws on top of the grommets.
4. Place #4 washers on top of the choke tabs and snug down with 4 #4 nuts.
5. Remove the existing 4K plate load resistors.
6. Solder the choke leads exactly the same way the resistors were soldered.
It took about 20 minutes total including the soldering.
Sort of an update here - since moving my Quickie to use as a linestage in my main system (between the DAC/Seduction and S.E.X. amp), the Hammonds are picking up some hum when the pots are turned all the way up. Now granted, I never turn the pots up very high, as there's plenty of gain, but I don't like the idea of any added noise to my signal, however small. (When used as a headphone amp with my iMac, the Quickie was dead quiet - but this was likely due to it being the only electronic device on the desk). Since I want my chain to have the same inky-black background as the S.E.X. amp when used alone, I ordered the PJCSS and will be swapping that in once it arrives. That should take out all of the "iron" between my components and the S.E.X. amp, as I already did surgery to remove the Specos and accompanying headphone circuitry some time ago.
If anybody is interested in buying my chokes, I'd sell them for a decent price (perhaps $20, including shipping, for the pair?).
Those are nice chokes for other projects. You can throw them in a preamp instead of plate resistors to check out the sound.
I had thought of that, actually. I already have a box of tube-related parts (in addition to my ongoing junk boxes of assorted resistors, caps, etc). from my various Bottlehead projects and upgrades, so maybe a homemade amp is the next place to go. I may eventually try out designing something simple on my own, though I'm a psychologist, not an electrical engineer.....
I'm probably not the only one who thought of this mod, but here is my posting "lifted" from the old forum:
The Hammond C156C chokes are readily available from AES, Angela, etc.  Same size as the Dynaco C354 and Hammond 156R.  I measured one of my 156Cs and it has a DCR of 3460 ohms.(They're still not yet in my  "modder" Quickie)
Posted by Dyna Saur (A ) on September 25, 2009 at 18:48:32
In Reply to: RE: Transformers posted by Paul Joppa on September 25, 2009 at 13:45:03:
Hammond has a couple of high inductance, low current chokes which may be usable as suitable plate loads for the Quickie's 3S4s.
155C, 60H, 8 mA, DCR = 2750 ohms, about $14 each.
156C, 150H, 8 mA, DCR = 3700 ohms, about $15 each.
Since these are both below the nominal 4.02K plate resistor value, one could insert an LED in series between the B+ line and the choke's "hot" side, for a pilot light, or tube activity indicator. Depending on the LED color, it will introduce between 1.6 and 3.6VDC voltage drop, which is pretty much minimal. Don't connect the LED on the plate side, it could introduce some unwanted noise into the equation.
Now, these inductors aren't going to be of Magnequest quality, but at the cheap prices, they may be a good deal for this application, along with the SPECO matching trannies. I'd SWAG that 2.2 to 3.3 uF would be a good coupling cap value , into the reflected 4K ohms. Voltage rating could be as low as 100V, but I'd probably go with 250V (basically because I have lots of such caps in my stockpile).
This topic alone has intrigues me to the point that I put in an order for not just one, but two, Quickies ;-)
Being one who can never leave "well enough" alone, these Quickies are a very interesting and readily modifiable project, which I just can't resist.. A little research indicates that 1S4s can be used with a simple re-conenction of the filament leads (use pins 1 and 7, leave 5 open). Just becuzz....
All of this talk of "quickies" reminds me of a very old, rude joke involving a pastor and a nun, but since this is a polite family-oriented site, I won't post it here ;-)
/ed B in NC
I had the chokes in my Quickie and they were an improvement, but the PJCCS is much better.
One or the other but not both at the same time.
With Dr. Toobz enthusiasm for the choke mod on the Quickie how could I resist.  Well, they delivered today and I decided to set up an experiment.  After all, who can resist a good experiment.
Basically I wanted to measure the spl in the room at given frequencies before and after the chokes were installed.  I had just picked up a RadioShack Sound Level Meter on clearance at the local Rat Shack ($14) and was looking for a way to put it through some paces anyway.
So here is how I set up the experiment.  I used a tripod to mount the meter in the room right at my normal listening position.  I used TrueRTA on my laptop to generate the tones and I ran them through my Tascam 32 tape player so that I could use the VU meters to insure that each set of tones was at the exact same level.  I set the meter to "C" weighting and Slow Response.  The volume on the Quickie was set to 12 o'clock as well as the volumes on both of the monoblocks.  I didn't want to be blown out of the room with test tones.  I then ran through several test tones at different frequencies adjusting the VU meters to zero as needed.  This seemed to compensate for some non-linearity in my laptops output.  I recorded the results, then installed the chokes and repeated without moving anything in the room.
Here are the results:
Frequency      4K Resistor      Choke (150H)
25                      55                    58
30                      60                    63
35                      61                    64
40                      64                    68
45                      68                    71
50                      72                    77
100                    82                    86
500                    81                    83
1K                      66                    69
2K                      64                    67
4K                      78                    80
8K                      65                    75
12K                    62                    67
16K                    58                    63
18K                    56                    58
20K                    56                    57
Definitely an overall increase in gain.  Especially around the 8K mark.  Interesting.
After all of that, I just sat and listened.  It still sounds just as wonderful as ever.  Maybe better, but I'm not really good at those qualitative sort of assessments.
Final note:  I run my quickie from an HP 6205C Dual Power Supply.  Since installing the chokes, I am picking up some hum that is probable from the transformers in the power supply.  With the resistors installed I could set the quickie right on top of the power supply with no problem.  Looks like I will need to move the PS further away.  I'm quite confident that will reduce the hum but will post later after making the change.
Final Final note:  If anyone has some suggestions about how the experiment could have been improved please let me know.  I tried to control for everything I could but good science needs peer review and if I'm not open to that then I'm not doing good science.
I applaud your efforts! This kind of thing is usually best done by measuring signal with a scope or DMM right at the output of the preamp. The room is going to affect the measurements too much to give more than a rough idea, which in this case says that the average overall gain increase is roughly 3dB (which sounds about right). It's just too likely that moving the mic even a small amount could have created the peak you saw at 8kHz, particularly when you use two speakers to generate the tones. Also, the RS meters are not very linear above about 4kHz.
You might adjust the experiment by running the laptop into the Quickie and monitoring the output of the Quickie by running it into the line inputs of your Tascam and monitoring the signal on the VU meters.
Thanks, that would definitely narrow things down.  I think I made the mistake of trying to include the whole system when I should have just focused on the item that I changed.  If I hooked the DMM (or my scope) to the preamp outputs would it be best to disconnect the power amp or do I need that load on the outputs?
Also, I moved the power supply well away from the Quickie with no real effect on the hum issue.  I tried with and without the DAC turned on and even switched the inputs to the unused RCA jacks.  No change.  It's not a bad amount of hum.  In fact, it is barely audible from ten feet but it is definitely more than with the resistors installed.  The air-conditioner gives me way more signal to noise problems than the hum and if you're in Southern Missouri, like I am, it just runs constantly right now.
I think Dr. Toobz is on to something here.  It is certainly worth experimenting with.
If you like the chokes, I would definitely recommend checking out the PJCCS. I find the CCS to be quieter and more linear than the chokes, though I still prefer the little bit of distortion the chokes add to warm up a sterile sounding digital source. The PJCCS is preferable, IMO, if you seek more gain and better frequency extremes without adding anything to the mids. The downside to the chokes, as I've discussed elsewhere, is that they start to collapse the soundstage and sound too "mushy" as the gain increases. At lower levels, there's not as pronounced of a difference between the chokes and CCS. This is probably attributable to non-linearities in the choke's behavior, but I'll let somebody with an "official" electrical background get into that mess!
