Been a while since my last post but have a frustrating issue that I can't seem to resolve.
I have a Rega Planar 8 TT with MC Apheta cart into Eros II.
Prior to the Eros, I had a Rega Aria phono which gave a noticable hum, getting louder as the volume was increased.
I understood this to be a ground loop issue which is apparently common on Rega TTs when mixed with other brand gear (running into Naim Pre and Power).
Issue was never resolved but was not all that noticable when music is playing.
When I installed the Eros, prior to fitting SUTs, the hum seemed to have disappeared.
I say seemed because as it is a low output MC cart and, prior to fitting the SUTs, volume would have to go quite high to the point that tube rush became noticeable before I noticed any hum.
I fitted the SUTs (20:1) and tube rush has gone (at any volume I have ever play it) but the hum returned.
I have lived with it for a few months but it is a constant irritation I would like to resolve!
My first question: is the hum a ground loop issue as I have assumed.
The sound is the same hum I get if I remove the RCA interconnect between Eros and pre-amp at the Eros end and touch the signal part of the RCA connector.
Second question: will attaching the shielding wires of the SUTs differently make any difference. They are connected to chassis earth (lugs 3 and 18).
Is signal ground different from chassis earth anyway as they appear to be connected between the ground post and lug 6.
Final question: If I haven't made a mistake and attaching SUT shielding doesn't make a difference, does anybody know a solution?
Additional information:
I have tried some of the suggested solutions found online involving connecting an earthing wire between phono pre and pre-amp.
I have tried from both the ground post and from the ground of the left RCA (this is where I understand Rega run their ground wire instead of having a seperate ground wire connected to the ground post).
Disconnecting the TT from the Eros makes no difference which would suggest it is not the common Rega TT hum after all..
The exact same hum is coming from boith channels.
I have tried different cables, home-made, purchased, shielded and unshielded, all to no avail.
I have also tried into different inputs of the Naim pre-amp, both RCA and DIN.
I have attached a photo of one of the SUT installs. Can provide more photos if issue elsewhere in the Eros is suspected though I was ruling this out due to it being an issue with my previous phono stage.
Any help or suggestions appreciated, noting that replacing the Rega TT has already been suggested more than once elsewhere.
Apologies for the long post but thought it better to provide as much information as possible.
Best
Chris
Best
Chris
