Fostex flats from madisound
pro_crip
Hi all, not quite a newbie here (got a modified foreplay II under the belt) with paramount 300b's on the way. I'm trying to find some speakers to go with them (along with an eros and a foreplay III). I know I need high efficiency and was wondering if anyone built either one of these: http://madisound.com/catalog/product_info.php?products_id=8282 or http://madisound.com/catalog/product_info.php?products_id=1399. And if they did, what were their impressions? Has anyone built the Fostex recommended enclosures? A friend of mine is a luthier so I'd have access to his shop and expertise for a bottle of Booker's (what a bargain). Any and all opinions will be appreciated. Thanks a bunch.
Rich
pro_crip@yahoo.com
I am using the Fostex 208E Sigma in an open bafle (as part of the Basszilla speaker) and driving them with 300B Paramounts.  Sounds fine and plays plenty loud for me.
i have built a jericho horn which is similar
and highly recommended--the basis being the fostex 208esigma--a very nice speaker-i added a ribbon tweeter. a fountek neocd2 --howie
I've got a pair of BK-16's scheduled for delivery for tomorrow. I'm going to use the FE166En's. I heard the original kit (FF165K's & the tweeters) a couple years ago at a Bottlehead meet & was really taken by the sound. Bear in mind that these are not exactly strong in the low bass. There really isn't much at all. I'd guess that 60Hz is about as low as you are really going to get. Maybe lower in a good room on a good day. I'm putting together a living room system so I'm mainly concerned with the mids & can't have anything too large. You might want to add a sub, but that's cheating.
That said, I use some FE206E's in a transmission line for my serious system. I can't say enough about the drivers. They are nice & fast & strong on the low end & I think have a nice response up to the highs. Don't point them directly at your listening position, though. Listen off-axis. My plan is to go for the BK-20's if the 16's work out.
The main reason why I'm posting is to say that if you have not heard a single driver speaker, you may want to before you invest. They have a quality all their own & are quite quirky. I personally feel that a single full-range driver is the only way to go, but many disagree. If you have only heard standard 2 or 3 way bass reflex speakers, then you might want to find a local bottlehead willing to give you a listen, a club or (shudder) a dealer.
On the other hand if you are new to this whole single-ended, low power business, then you might want to take the plunge & don't look back. If you don't know SET's, then find out about them on full range horns. You could do worse for yourself.
Please do look at PJ's BSC filter for single driver full-range loudspeakers.  This little modification can really bring some life to the bottom and top end of these drivers.
I owned and them.  Great mid range and imaging that a single driver can give but that's about it.  The 166's with the whizzer cones hurt my ears.  I had better results with the 165 drivers in near field.  I couldn't get any lower than 50 Hz out of them and it was way down dB.  I wasn't running tweeters with them and they rolled pretty heavily after 9 or 10k Hz (memory slipping).  Replaced them with Altec Model 19's and haven't looked back.  As a note, the cabs are not as easy to glue together as they may seems.  If you don't have plenty of extra clamps, you may want to consider having a carpenter glue them up for you.
The experience with them has inspired me to try a higher quailty single driver full range or even a two way OB set up with active crossovers, someday....  Good luck and enjoy!
I like the Decware driver a lot and by inspecting them it made me realize how to mod drivers...so next time I was able to purchase the regular ones...
pro_crip said:
Thanks for all the responses. I've decided to go with the BK-20's with these: http://www.decware.com/newsite/DFR8.htm. Decware also has a nice looking sub http://www.decware.com/newsite/wo32.htm that I'd give a go at in the near future if the bass response isn't to my liking. As far as PJ's BSC, that'll require some research and considering I just got back from dialysis that'll happen this weekend.
Keep us informed on how the project is going.  I am considering building the same speakers.
Deb
after looking at too many options for fostex drivers, I went with the "singular" by Onur Ilkorur. You can read alitel about it at
http://www.yildiz.edu.tr/~ilkorur/ILKORUR/index.html  and  http://www.bd-design.nl/contents/en-us/d8_DIY_Speakers.html
I have my singulars hooked up to a stock SeX amp and I love them.  Imaging and dynamics are excellent.  But as someone else wrote, they can be quirky.  The sweet spot is small and the high end can be shrill.  But there are ways to control this.
If you are putting a 207e into a "horn" style enclosure, I would recommend the 206e instead.  I have not tried both myself but after studying the specs and reading about results, I think the 206e is a better way to go.
But, the 206e is much more likely to need PJ's BSC as Caucasian Blackplate recommended.  But with the paramount you should have plenty of power.  I have so far only used the phase plug mod of adding a wooden plug where the dust cover once lived.
http://www.planet10-hifi.com/pp-info.html
Burn in is very real with the Fostex designs so do expect things to improve in a number of ways after the first few hundred hours.
JP
I built the BK-16 flat pack a few months back with the FF165 drivers. I don't have a SET right now and use it with a Quickie and my Fisher SA100. I am finishing up a RH84-se for these right now (and a Foreplay and some Dynaco MKIII's -- to many fires burning, but I love it). I have also heard the BK-20 at a friends place with a SET amp using 6V6's.
I love the presentation of my BK16. I am a real stickler for well defined mid-range, especially in the 800hz to 1Khz range where lower harmonics and middle fundamentals begin to collide. And where I think the beautiful honkiness of a Les Paul lives. Maybe this is due to the quick response of the FF165, other people here more wise and experienced could probably explain that better. Now, I don't have a lot of experience with full range drivers, but I also now understand some of the criticism I have read.
Robben Ford's Cut Me To the Bone enveloped me and most of Karajan's Beethoven symphonies are astonishingly clear, vivid and powerful with exceptional dynamics.  Some of the better recorded Dead shows I have absolutely set the entire stage right in front of me. The depth of the piano on one was so convincing that for the piano to my left, the high keys were closer to me and the lower ones were further back towards the wall -- just like the piano was in the room. I have only ever heard that phenomena once before from some Magnepans driven by a Mac tube pre and a big Mac SS and playing some great Brubeck.
But I have some Vivaldi that sounded like it was coming from a stock car stereo and some Beatles and Cream that was a little shrill.
One thing that shocked me with the BK-16's was how much bass it actually had. It wasn't like a sub or a great full range, but much better than I expected. Which makes me interested in trying out the Decware 6" to compare against the Fostex. The heartbeats on Dark Side of the Moon had some nice punch and almost the tiniest bit of rumble. Most importantly, it was pleasing and I didn't want to stop listening.
I am very intrigued by the Decware 8" for a taller folded horn design for when I decide to build something with 45's, 2A3's, 50's or 300B.
Still searching for a perfect match for my Fisher SA100. I am going to build a Two PI tower next to try for that amp -- then a Four Pi ;)
NotBen,
Good observations there.  The DSOTM on that small a speaker giving a decent heartbeat is pretty amazing!  I took the same path as you, bought sensitive speakers then the SET.  It just doesn't work the other way around.
Since you didn't mention it, did you give the Fostex drivers a good break in?  They are not like Lowthers which take a year or so, but do need a hundred hours or so with hard driving.  It is supposed to get rid of the midrange shout, which I haven't heard but it is often reported.  Maybe I have only heard well broken in Fostex drivers like Terry Cain's Abbys at VSAC 2003.  That was awesome!
Decent heartbeat mind you, not the full boom and rumble of a sub, but enough that I wasn't totally disappointed and was pleasantly surprised.
As far as break in is concerned, I think they have at least three hundred hours or more on them. I bought the drivers last summer and put them in some old book shelf cabs and used them with a sub to listen to while tweaking some other stuff. Then recently did the flat packs. I pounded them with quite a bit of Radiohead :)
My crack, eros and extended foreplay iii are here with the paramounts showing up tomorrow. The BK20's are here already and the decwares arriving in a day or two. I still need the BSC schematic. The only upgrading I'm doing at the moment is loading up on various Mullard tubes. I've got quite a bit of building ahead of me. I can't wait.
I built a pair of the Madisound BK-16 kits (and Fostex  FE165K drivers & T9A supertweeters. Very nice sounding, and surprisingly good bass from a relatively small diameter driver.  I won't attempt to wax poetic about the mystical sound qualities ;-)  They took around 100 hours to start sounding "right" and have improved with subsequent use.   I have not yet finished the cabs, they are still teh natural wood (Baltic Birch plywood).
Here's a shot of the system:
The rubber yellow  frog and blue lizard add nothing to the sound quality ;-)
and a close up of the Paramounts and FPIII modified to use 6SN7s, a stepped attenuator, and only one set of inputs.  The CD player (Rotel RCD85 is "hidden" in the cabinet under the amps.
I am considering purchasing a pair of the BK-20 flats, to use with my FE208Es.  The prices on these cab "flats" has risen considerably over the past couple of  years...    I wonder if the plastic  phase plugs from DecWare may do the 208s any good (not the same as their original phase plugs which were hex  socket wrenches)..
/ed B in NC
Putting together my Paramount 300B's.  My first SET, so the search is on for a more efficient speaker.  At some point, I will get Altec 604 8H speakers with as yet to be determined enclosures using Jeff Markwart's XO design..  At present time I don't have space- and if I did, I'm not sure the Altecs would work well in a smaller sized room.  Other than in the case of the Altecs, I'm a believer in smaller full range speakers- my current set and by far best speakers I've ever had are a knock off of the Bowers & Wilkins 805 SD tear-drop shaped speakers.  But not efficient enough- I wanna try something new anyway.
So: I almost ordered some BK-16 flats and Fostex FE168E Sigma's from Madisound- but in reading up, I noticed that not a lot of people were ecstatic about these- some were somewhat underwhelmed.  The BLH design is very interesting, and I'd love to try them- but I've never heard them.  I don't have the time or workspace to play carpenter at this time, so the flats are attractive because of ease of assembly.  My vinyl system is already a little aggressive in the mids and upper mids (seems to be a common complaint), so I gotta be careful.  Internet streaming off Spotify thru my Mac Mini and DAC (no preamp) is well equalized and sounds great.  I am aware of the BSC options (saw a lot about this in some big DIY threads about the Tang Band 8W-1772 full range speakers).  Sounds like a BSC might be helpful with the BK-16/Sigma set up.  I'm looking at the 6.5" design because I believe may be better in a small room.  Also looking at BIBs and simple bass reflex box Godzilla built.
You guys that have them, what do you think?  Advice from anyone welcome.  Of course, I'm also searching AA High Efficiency forums.  Much thanks, Kip................
Before the SEXy Speaker, I made a 1.0 cubic foot reflex box with FE167s. We thought there was too much excursion demanded, causing an overload congestion whenever there was a lot of deep bass, so the SEXy put the same driver in a smaller 0.25cf sealed box and specified a subwoofer per channel crossed pretty high. So I have my doubts about 6.5" Fostex drivers in ported boxes, unless you are listening to music without heavy bass, i.e. small jazz ensembles and chamber music.
Back-loaded horns usually have very small mouths relative to the wavelength at low frequencies, so they have uneven response. Of course most rooms also have uneven response due to room modes, so that is not always perceived as an issue. On the plus side, the horn load on the back of the diaphragm can be more efficient than the direct radiation from the front, producing the BSC effect naturally. I have not tried a detailed design, not do I have more than a very little experience listening to these, but I expect that they can be capable of excellent sound if well designed.
My two cents.
Back when a Foreplay 2 was $149 and Paramours had just come out the Fostex 104E was enthusiastically endorsed here and elsewhere as a great value in the Fostex recommended enclosure. I built it and thought, like Johnson, that the mid-range was superb, the imaging other-worldly but the treble made it overall sound like an AM radio.
I know that newer 6" and 8" Fostex drivers sound quite a bit better and have heard Bob Brine's speakers, with BSC crossovers, sound very good. In addition, the Fostex cabinets are far easier to build than they look, even to a Tyro. I came up with a construction method that others have found easy to use for their labyrinth horn projects.
First, forget about how many pieces there are to cut; they're all the exact same width. One rip fence setting does them all. In fact, you MUST cut them all in one session or somehow not let the fence move in between cuttings so that they're all exactly the same width. Once you rip all your plywood a chop saw with a stop makes quick work of each set of the various sizes.
After I cut all the pieces to size I  placed them on one cabinet side piece and traced the positions with a soft lead pencil. Then I shot beads of construction adhesive from a tube, Liquid Nails, PL400, whatever, inside the lines , took a piece of plywood larger than the actual side piece, laid it on top and weighted it with 2 -25 lb. bags of lead shot. After an hour, with the glue sufficiently set up so the pieces wouldn't move, I shot beads of glue on the tops of the baffle pieces, laid the remaining side on top and weighted that. Finally, I nailed #4 finish nails, just a few, around the perimeter, countersunk them, then flipped the cabinet over and nailed that side. This last probably wasn't necessary but made me feel better ;-} I also glued on thin strips of Mahogany to cover the exposed plys.
This will of course work equally well with the Madisound Flat Packs. Also, before there were Home Depots and Lowes every neighborhood had a lumber yard and many still do. Provide one with a cut list from the Fostex plans and for a fee, they'll cut your plywood to size and sell you the glue and nails. Then it's off to the Hunting Supply for Lead Shot.
