Foreplay III redux Fi edition
But that would have scared me off from diy audio!  Then again, being an FW, I probably wouldn't have heeded the warning  ;D
The fundamental issue is that a fuckwit will open it anyway, warning or not. That's why they are a fuckwit. Come to think of it, I guess that makes me a fuckwit.
We all are fuckwits at times. I still remember when i was about 5 years old and i stuck a wire in a wall outlet.
That was the seminal moment that shaped my misguided life!
Making progress today, will post pic's later. It's been 2 and a half weeks with temps in the upper 80's to low 90's and high humidity.
I'm melting.
Ok, today's progress.
The first pic is the back of the power panel complete. the second pic is the front panel as i progressed today. The tube side is complete except for the grid and plate cap wiring because that will happen after the panel is bent. On the left side i am in the process of wiring the input selector, balance and volume control in which i will then remove once completed and transfer to the input panel for final wiring,
At that point when final assembly occurs all i need to do is secure those 3 control's to the front panel. Hopefully. Hey Bottle head crew, i'm gonna try a 10k balance pot, any thoughts? Peace out all, stay cool and safe.
Since the FP-III didn't come with one, you'd need to draw out what you plan to wire up and we could comment.
Outstanding work - this thread is just the thing for the monotony of quarantine (quaranotony?).
Will you enclose the edges to exclude the probing fuckwit fingers, or will this preamp do double duty as something of a fuckwit porchlight/bugzapper?
IIRC Don used perforated metal to make grills over the gaps between the panels.
Roger that big daddy, i have a couple of in wall spk brackets with perf metal wings that i can use. Gotta find them but i know i have them. i used to be in that business.
Ok, more progress. I have all the wiring done on the front panel except for the grid and plate wires soldered which will happen in the next day or two, after i bend the front panel. I have cut and bent the F.W. finger protectors, they are ready to install. and lastly the input panel is bent and the input padding resistors are installed. Btw we are in the midst of the first tropical storm of the season, anybody want want to come to the north fork of Long Island N.Y. to pick up some fallen limbs? Hey Doc i heard that lawn care is your side job.
Sorry, i just could not resist. I know, i'm a jackass. Peace, Love and happiness to all.
Nice!  How did you bend the perforated sheet (aka FW finger protectors)?
Oh, bad timing, what a shame. Our son and his fiance postponed their garden wedding until next year and I have temporarily retired from landscraping. But I will send pleasant thoughts your way as you sweat over the chainsaw and chipper.
Roger That Doc, Sorry To here that u Are not available, perhaps i can find someone else. Say hi to Queen For me, Luv you both.
Deke, i bent the F.W. protectors by hand using the last flat(unbent panel) with the standoff's installed and a couple of spring clamps to hold the previously bent corner. Again, P.L.and H to all. I'm out 4 Tonight.
Hi Lee,
I'm a reformed Long Islander from Suffolk County. Good luck with the weather event.
Hey I have something cool if you want it (and if I can find it). Bottlehead often presents, "while supplies last" type offers. For example recently a premium RCA 12AU7 clear top was offered with the next X number of Crack kits... That sort of thing. Well years ago when I bought my FPIII the goodie was a Vitamin Q bypass cap for the 0D3. I upgraded to the Extended Foreplay which eliminates the 0D3. Somewhere I have that cap still attached to an octal socket. I no longer have a need for it if you want it. I can also put some NOS 0D3 tubes in the box. No charge to you. I'll even pay for slow boat shipping. Just let me know.
Hey Natural Sound,
I got lucky this time, no damage and never lost electricity. Just a bunch of limbs and branches down.
Thanks for the generous offer but you should keep those items, you never know when that cap may come in handy.
Thanks again,
Regards.
Okey Dokey, I am so close to hearing music. Got the front panel completely wired as well as the power and input panels.
All that is left is to hook up the B+ and heater wiring.
Hey Folks, I know some of you may find this hard to believe but, I AM AN IDIOT!
I finished the wiring and did a resistance check and all seemed fine( i thought)
I then plugged the power in and the monkey flipped the switch. The 0D3 fired up nicely measured 146 vdc on the plates awesome!
then when the tubes started to conduct the B+ dropped out. As it turned out when i ordered the parts i needed i inadvertently ordered 22.1 ohm 1w resistors instead of 22.1k resistors. Lesson learned is that when i did the resistance check i missed the fact that it didn't show that little K after the value. I'm a dope.
So i have an order with Mouser, should receive them on monday. I assembled the chassis and took some pics any way.
I still need to fab the brackets that will hold the feet in place, i guess i should focus on that until Monday
Peace Out.
Thanks Derek,
It was a nice challenge to design the chassis plates and associated electronics for this project, it seemed to daunting to me to do so
when i built the Fauxplay III, i decided to build a more traditional design. But i have always liked the look of Don Garbers designs and i am sure i will love this preamp once i get it sorted out.
I may have to build a 2a3 or 300b amp in that style to compliment this preamp.
Regards,
Lee.
