Currently my Quickie feeds a rotation of power amplifiers, and a pair of Visaton B200 full range drivers in open baffles. Cheap and dirty, but I like it.... Well sort of...
I am adding four 18" woofers running off of a QSC MX1500a to my system and am going to be bi-a ping the system.
The initial plan was to use an all active setup, but am not keen on the idea due to some experiments. I will eventually build the Linkwitz MT1 and WM1 boards, but for the time being, am looking towards passive line level crossovers for the full range drivers, and then running the active crossover on the low end. But may use the PLLXO on bass as well to avoid extra components.
Can the Quickie be modified for a second output properly? I assume its more than just running wires to another pair of outputs from the other set, yes? Can I build the PLLXO into the Quickie?
Any help would be great thanks.
