Alex.podaru
Hi,
I've just completed my first Kaiju kit and started using it to drive a pair of Harbeth SuperHL5 (not the most efficient @ 86dB). Even before connecting it to the the speakers I've noticed the power transformer making a slight hum during the voltage tests, is that normal? Once the speakers were connected the the hum balance was brought to a minimum there is still a relative low hum, not you noticeable while listening music unless there is a quiet passage.
The other thing I'm curious about is that the Kaiju doesn't seem to drive the speakers too loud (or as loud as I was expecting them to... would be the more accurate statement). I've previously built a S.E.X. 3.0 for my headphones but was pleasantly surprised to see that it could drive the Harbeth to decent levels, with crystal clear sound albeit lacking a bit of "oomf". Now the sound out of the Kaiju feels much richer and definitely has that "oomf" that the S.E.X. was lacking, but with its power rated at 8 times that of the S.E.X., I was expecting a little more loudness. I have both amps wired for 4ohms at the output transformers and they are very similar in term of loudness (with an ear test only). Is this normal or did I wire something wrong somewhere? Am I understanding the power rating wrong?
As you can probably tell I am quite new at this and would appreciate any input!
Thank you!
aPodz
Thank you!
aPodz
