Natural Sound
Active member
Finally getting around to installing my extended foreplay kit. I'm building the C4S boards and the instructions say to install a 237 ohm 1/4 Watt resistor into R1. My kit came with 4 really tiny 237 ohm 1/8 Watt resistors. Will this be OK or should I get the 1/4 Watts?
For clarification, the 237 ohm resistors are the same size used in the whispers and padding resistors. I'm pretty sure those are 1/8 Watt.
