Wade Winnett
I recently finished the Eros phono preamp and listened with utter joy for two days until (noise/crackling) reared its ugly head on the A/Black channel. All Ohm/voltage checks through the entire build were consistent and well within spec. Diodes were always immediately and well lite at all checks. The (IB) on the C4S board now showed 235 VDC. I followed the trouble shooting section of the build manual. I inspected but never saw an obvious solder issue. I have removed all boards at least twice in order to inspect and reflow. Most point to solder points were re soldered. When I was dissembling I was able to recheck good voltage on page 40. I was starting to run out of patients but page 55 voltage check confirmed 235vdc. All tubes are NOT heating(illuminating). I did one last Ohm/voltage check. Ohms are still good. Voltage numbers are my first and last check. IA:216.8-297.5, IB:216.4-297.3,OA:164.3-289.2,OB:161.6-295.2, OC:96.6-185.8, OD:96.7-66.8, OKA:97.5-40.2,OKB 97.9-64.4, OKC: 1.412-1.795, OKD: 1.660-1.511. Diodes on the C4S are working, diodes on the shunt regulator are not illuminating. Fuse was never blown. This is my third Bottlehead amp kit with my Moreplay and Crack with capacitor upgrades. I also have an Akitika GT-108 power amp, and Zaph audio ZRT2 speaker kit under my belt with few issues. I have also made my own power and RCA cables. I know that I have a beautiful and exquisite sounding system with the Eros the final piece. Any help or advice is more than welcome.
