Ah yes, thanks for reminding me. I haven't measured the preamp yet, but did some measurements on the Eros itself. I think these results point more to a problem in my build than an issue with the preamp.
I hooked up a few test signals, here are the results. I used a signal generator on an iPhone and measured with my scope probes. Don't know if I needed to match any particular output load(?)
All measurements peak-to-peak, 20mV input
60Hz: 1.3V out
500Hz: 0.5V
1kHz: 0.35V
10kHz: 0.30V
20kHz: 0.22V
Both channels measured approximately the same. It appears that even the 60Hz level is below nominal. Or am I fooling myself because I'm not using an inverse-RIAA source (although 1kHz should be the 0dB point on the RIAA curve, yes?)? Sorry for the clueless questions, I'm learning as I go.
Are there any good internal nodes to measure to try to track down the missing gain?
Many thanks for the continued help.
-David
60Hz: 1.3V out
500Hz: 0.5V
1kHz: 0.35V
10kHz: 0.30V
20kHz: 0.22V
-David
