I have been running a heavily modified Seduction since 2002. Love it. The mods are serious surgeries with off-board power supply and additional output section. The mods added a lot to the sound which I liked.
I’m planning to move on to the Eros 2 and will do similar mods by using the exiting parts from my Seduction as possible.
Here are my Seduction mods and a few questions:
1. Mundorf silver/gold caps in the RIAA circuit. Is the Eros use the same RIAA cap value so I can use my Seduction caps?
2. The off-board power supply is: 260-0-260 tranny, 6x4 rectifier, balanced chock input loaded, followed by CLCL, followed by OD3 regulator. The original tranny stays in but supplies 6DJ8 heaters only. What is the min voltage input supply required to the Eros HT regulator? Will the 6x4 and chock power supply benefit Eros? BYW, any idea what is better from the Eros HT regulator sounds compare to OD3?
3. I added a 5687 tube output section to the Seduction. It is kind of combine a preamp into the phono amp. It is then able to drive a passive preamp and longer cables. So I can retire my Foreplay which had an off-board tranny, chocks and OD3 power supply. The original Seduction output coupling caps were removed and the 6DJ8 directly couple to a 5687 tube (grid at around 70V). The 5687’s plate is loaded with a 5K:600 transformer. Is the 6DJ8 section in the Eros similar to the Seduction so I can use the 5687 output section as well?
