Eros Build Resistances Consistently Higher Than Called For
ZenAudio
Just finished my Eros and have the following resistances that are higher than called for:
2    85.4K  71K
4    74.9K  60K
9    46.6K  39K
10  46.6K  39K
12  74.9K  60K
14  85.4K  71K
A4, B4  .621K    *
A6, B6  74.9K  60K
C1  46.6K  39K
C2  75.1K  60K
C4  .621K    *
C6  46.6K  39K
C7  75K      60K
Because these measurements are more than 15% high, I thought I'd post before firing her up.
You're OK. When doing the resistance measurements you are mostly making sure there are no zeros where there should be a higher reading (and vice versa), that would indicate a miswire. Small variations like you are seeing usually happen because different DMMs react differently to capacitors in the circuit getting charged by the DMM's battery.
