I just got the kit all built and soldered with no leftover components and did the resistance check on pages 75 and 75 of the instruction.
Nearly all of the measurments are within the 10 to 15% range but there are a few that are about 20% higher than optimum in the instructions.
Terminal Strip
2. Should be 71K ohms. It reads 85.5K with one meter and 83.4K with the other.
4. Should be 60k ohms. It reads 75K with one meter and 73.3K with the other.
12. Should be 60K ohms. It reads 74.9k with one meter and 72.8K with the other.
14. Should be 71K ohms. It reads 85.3k with one meter and 83.8k with the other.
Nine pin sockets
A6. Should be 60K ohms. It reads 75k on one meter and 73.3K on the other.
B6. Should be 60k ohms. It reads 74.9k on one meter and 72.9K on the other.
C1. Spec is 39K ohms but it measures 46.7k
C2. Spec is 60k ohms. It reads 75.1k on one meter and 73.6K on the other.
C6. Spec is 39K ohms but it measures 46.6 ohms.
C7. Spec is 60K ohms. It reads 75K on one meter and 73.1K on the other.
Is it okay to put the tubes in and go to the next set of measurements? Visually it all looks right.
Interesting that A6 and B6 measure the same.
The meter that reads a little higher is a Klein Tools and the second readings are from an inexpensive Gardner Bender
Terminal Strip
Nine pin sockets
