Eros 2 Step-up Transformers
Thanks, I realise it was a prototype. Is the rest of my assumptions on resistor placement correct?
I suppose I will can get a gauge of the load impedance (when the device is off) by measuring resistance between the ground and the input jack for each channel?
Can I execute the other resistance checks that come in the manual after the Sowters are placed? Which checks would need adapting?
Thanks again for all your help, I'm almost done building and can't wait to hear the results.
You cannot measure AC impedance with a DC meter.
I did not find any immediate errors with what you posted, but as always it's a good idea to double check against the pictures I posted.
Hi folks,
I'm in the process of changing over to a Hana SL MKii w/ cartridge impedance at 8 ohms and recommended loading at greater than 80 ohms; output is 0.4mv. I have the Sowter 1990 step-up transformers.
I've read the Sowter guidance, and thus, have worked out that likely loading (with a 1:10 ratio) should be 8k ohms.
In terms of the directions (pasted below), I'm a bit unclear. Do I completely remove the 47K loading resistor (which, I assume, is conventionally used for MM cartridges) and then put an 8k resistor on each side across the secondaries (1/2 and 16/17)?
1.  Pop the resistors out of each RCA jack that go to pin 9 on each EF86 (leave them attached to the socket, just pop out the end sitting in the solder cup of the RCA jack).
2.  Remove the 47K loading resistor on each RCA jack.
3.  Reconnect them at terminals 2 and 17.
I'm new to MC cartridges and SUTs, so just wanted to confirm.
Nick
Yes, you would remove the 47K resistors and place an 8K resistor across the secondaries. Reply number 4 and reply number 5 in this thread have pictures of this.
Thanks, Paul!
One more question: Is 1:10 the ratio you would recommend for the 0.4mV output on the Eros 2? I have the 1990s, so I could opt for the 1:20 ratio (and I suppose, in that case, 32k loading resistors), but I'm not sure what would be ideal.
Appreciate all your help!
A .4mV LOMC into 1:10 will give you a nominal output level of 4mV. Around 2.5mV-5mV nominal is right about where you want to be for the Eros. 1:20 will put out 8mV nominal which is a bit too hot and could push the Eros into clipping.
