georgeged
Just finished my Eros. Very happy with sound – very natural and warm. Thanks to all BH team for the great kit!
I made few changes / upgrades to stock kit:
1) Tube sockets are now premium machined Teflon
2) Most of MF resistors - Dale RN's, CF – Takman 0.5W
3) RIAA capacitors are matched within 1% tolerance to recommended values (I bought additional 10pcs of each value). 76.8K & 10.5K resistors (“ideal†values recommended by PJ) are Dale RN 0.1%
4) Almost all terminals (except 2 x 3-lug) are removed. I done it to make as less solder points as possible
5) Earthing is “star†type.
6) Most of hard wires are 1mm pure silver annealed silver wire (on the pictures the are in Teflon tubing; I had a piece from previous projects). Solder used is lead-free 4% silver.
7) Power supply: 270R resistor replaced with C-7X choke; instead of 100uf electrolytic cap now is 120uf PP film.
8) 0.1uf capacitors on Shunt Regulator board are now CDE 942C
9) Output capacitors are MIFLEX KPCU-01 Copper Foil, Paper/Polypropylene-in-Oil 1uf 600V
10) And finally, NOS tubes are: EF86 – Valvo, E88CC - Tesla Gold Pins, ECC82 - RFT
