A few months ago my Eros 1 failed after years of service. I started to trouble shoot it and then decided to upgrade to the Eros 2 which is now in my system. Just today I got back the the Eros 1. Resistance checks are fine throughout. When I checked voltages the right side was all in spec. There is one (1) discrepancy on the left side. The OA voltage is supposed to be 170 Volts and is only reading 102 Volts. I replaced all of the transistors on the board except for the 4250A's since I do not have any. This far nothing has worked and the voltage at OA is still 102. I did find that the 220K ohm resistor was only reading 170K ohms so I swapped that out and three is still no change in the voltage at OA. Ideas?
