fritzthecat
Hello
I'm chris from Switzerland - my first post in here...
just got two Kaiju kits for my active 3 way horn system - the Kaijus are for midrange and high channels. For bass (Klipschorn, self built like almost everything in my actual system) I'm using two Silvercore 833c monos.
If I measure IA on both sides I get 421 V @ 235 V AC input - much to low - before all measurements went fine. Nevertheless I get the needed 300 (298) V on OA.
Adjusting the voltages @ 32U and 46U with the trim pots - I get 175 Volts on the A Side board. On the B side as well in the beginning - then I thought let it sit for a while and measure again and after maybe 20 minutes I get 186 V on the B Side board at the end of the trim pots way and the voltage seems to even climb higher - that's where I pulled the plug - what may this be?
And why are the voltages @ IA to low - before all values in the high voltage tests were within tolerance (521 V @ 14U), all others well within tolerance as well.
critical? What to do / check / resolder / replace?
Thanks for advice.
chris
Thanks for advice.
chris
