Driver and output tubes recommendations for super simple SET learning exercise?
  • Thread starter Thread starter Deke609
  • Start date Start date
My original search may have turned up the only Mullard sheets that don't. From the National Valve Museum: http://www.r-type.org/pdfs/el34.pdf
But the sheets PJ linked to and another Mullard version I found this am do have the triode curves.  So all good.
cheers and thanks,
Derek
@Tom-s: thanks. Yeah, that's the one I found this am. I had looked at Frank's EL34 page last night, including the Phillips and Svetlana sheets and a couple of others, but having already reviewed the Mullard sheets from the National Valve Museum (which as best as I can see does not have triode plate curves) I wrongly assumed that all Mullard sheets would be the same. Not so. Lesson learned: different versions/datecodes have different data.
cheers,
Derek
