Evening All
I am in the process of building a pair of speakers based on a DIY near field line array concept. Each speaker will consist of 25 "full range" drivers and the plan is to run them from my MonAmour Amps.
The driver is the Tymphany TC9FD18-08 from parts express. I will try and insert a link to the product page below.
https://www.parts-express.com/peerless-by-tymphany-tc9fd18-08-3-1-2-full-range-paper-cone-woofer--264-1062
My intent is to wire the array as 5 paralleled groups of 5 drivers connected in series. I am not intending to apply any power tapering which some folks employ to reduce the output of driver groups as they move out from the center. My fairly basic understanding of the electronic impact is that by having the same number of driver groups as drivers in a group, the amplifier would effectively see the same load as a single driver. But because of the increase in effective surface area achieved through having multiple drivers I should expect to see some increases in the overall efficiency vs a single driver.
My amps are currently wired on the 8 ohm taps and I was planning on leaving them in that configuration.
So I guess the question is, does anybody see any major concern with my plans from an amplifier loading perspective or should I consider utilizing a different set of output taps to provide better protection and/or performance?
Any thoughts or opinions greatly appreciated.
Phil
Phil
