I am assembling the BeePre and the BeeQuiet simultaneously. I have completed the BeePre and the only thing left to do is install the BeeQuiet resistors on the switches, everything is up to the BeeQuiet terminals. A quick glance at the circuit indicated to me that shouldn't matter, I decided to do my resistance and voltage checks now.
Resistance was good on 1-10 except 10 - which should be 20K+ but was 1.8M (so maybe that's right).
B side C4S LEDs are NOT lit up. IB is 190V. 300B Tubes are not lighting up.
Voltages on 1-10 (3, 5, 7, 8, and 9 should be 0V and are).
1. Should be 5v - .77V
2. Should be 90-110V - 189V
4. Should be 9.85V - 1V
6. Should be 146V - 190V
10. Should be 186V - 192V
A2. Should be 0V - 190V
A3. Should be 90-110V - 0V
This is duplicated with a few volt variation on the terminal 11-20 side.
Is there a load in the volume controls that has to be there for this to work? If that's the case, would I have damaged anything during this? I didn't see how it would matter, but the fact that I have the exact behavior on both sides makes me wonder if I missed something.
I will wire in the volume resistors as soon as I get your feedback.
-Dan
-Dan
