d cell solution
aragorn723
Hi everyone,
Just came across an interesting solution for D cell batteries on amazon.  It is a D cell adapter that allows you to put 2 batteries inside to increase capacity!
http://www.amazon.com/ColoYourLife-Colorful-Converter-Microfiber-Packaging/dp/B00CI5BJ7I/ref=sr_1_5?ie=UTF8&qid=1390008748&sr=8-5&keywords=battery+d+adapter
Think it will work well?
Dave
A D-cell alkaline battery is "supposed" to be 17,000mAh, a AA of similar quality will be 2,100mAh.  If you put 2 in parallel, that is 4,200mAh (with some assumptions).
So, you would really want 8 AA batteries in parallel to get close to what a D cell will do in terms of lifetime.
Duracell D-cells are about $1.50 each, AA's are $0.40 each.
charger said:
at which voltage Dcell have to be changed ?  at 1 Volt does they are still good enough to feed the Q ?
I run mine down until there is either A. Distortion or B. No sound. The Q will let you know when its time. That's how I do it anyway. I don't think there is a "magic" number for the voltage.
Ciao,
I use this adapter.
In my opinion it can be useful if you want to use rchargable batteries, as AA ones are cheaper than D.
Will 4 batteries inside D Size Spacers work better in Quickie?
http://www.amazon.com/eneloop-SEC-DSPACER4PK-Spacers-battery-cells/dp/B002V8C3W2/ref=pd_sbs_hg_2?ie=UTF8&refRID=1T5E0A093MQ6DPKCWX1J
The average alkaline D cell is rated for 12,000 mAH.  A rechargeable AA will be 600-3000mAH.
The link that you posted is for an adapter that will put one AA cell into a piece of plastic that fits where a D cell would go.
