Crowd sourcing recommendations: The Crack
Jameson
Intern in Chief
Staff member
I want to try something new. Folks constantly ask us what equipment works well with our gear. It’s impossible for us to listen to every combination, as much as we’d love to be able to, so I’m asking our community instead. We’ll start with an easy one: what are your favorite headphones to use with the Crack?
Old standbys like the Sennheiser HD6XX and 800S will be there, of course, but I’d love to hear what else will work.
I’ll go first: Recently I tried some ZMF Atriums and liked the sound.
Ok… go!
Beyerdynamic DT 1770 PRO (MKI 250 Ohm) are a decent closed option with a few caveats. The bass is totally outta control (in a bad way) but can be largely tamed by putting a piece of electrical tape over nearly (but not all) of the vent hole.
Build quality, comfort and isolation are top notch IMO.
Important to note that a low impedance MKII version is out there now and wouldn't work well with the crack.
DT880 600 Ohms are the best pairing to Crack I have ever tried. Better then any Sennheiser or ZMF that I have compared with.
DT770 250 Ohms Pro also very close
Any experience with the DT990 600 ohms?
Jameson, did you try the Atrium open or closed?
I have a pair of each. I preferred the open backs on initial testing but haven’t put enough time in to say that definitively. Now that we’re moved into the new house I’ll have to do a better comparison.
I have a couple pairs of modified DT 770 Pro's with 600 ohm drivers. I purchased a couple pairs of DT 770's 250 ohm and replaced the drivers with the 600 ohm version (https://www.markertek.com/product/byd-935037/beyerdynamic-935037-600-ohm-headphone-driver). I think I literally purchased the last two pairs from them as they haven't been available since.
The headphones are an excellent paring with the Crack, there is exceptional detail and very good tight bass. Of course Beyerdynamic is known for way too much high end so I have to EQ that down with my Schiit stack.
I also tried the DT 880 600 ohm, and I like the sound stage, but the bass of above DT 770's always brings me back. It's so deep, tight and impactful that my brain thinks I can feel it.
I have it paired with a Schiit Modi Multibit DAC and a Raspberry Pi with Volumio on it. The Pi has a HiFi Berry header with coax and SPDIF outputs that I plug into the DAC. The multibit DAC is more "analog" almost like listening to vinyl.
I'm listening to (and enjoying) my Crack + Speedball with Audio-Technica ATH-R70X headphones at the moment. The new version (ATH-R70XA) saw a slight change of tuning but kept the impedance at 470 ohms. So either is Crack friendly.
