Hi everyone
As mentionned in a previous post, I have completed a Crack with speedball option, step attenuator DACT CT-2 (100K) , Mundorf film capacitors on audio path and choke 157M ( 8H, DCR=259 ohms) .
I did a verification on each step with success. However I have some issues:
1) The DACT has 23 steps. If the audio signal is off and I turn up the volume I can hear some crackling on each step after step 16. Is it normal?
2) With the audio signal OFF, I notice if I put the volume at max and reduce to mid level or 3/4 level, I can hear a kind of strange low level noise. The noise looks like an old dial-up modem in the 90s. The noise stops after a while. Any body can explain that?
I am using a Beyerdynamic DT880 Pro. In fact I built this amp for one of my friend.
My friend is using a ZMF vérité with different home and the noise is a bit louder.
I also have notice today that my 120 Vac outlet at home shows open ground with Klein Tool tester.
Thank you
Thank you
