eeyore said:Got my kit today and looking forward to building it. My plan for upgrading is to build the kit as is, without any modifications. The 'upgrades' I have in mind include;
This should have the greatest impact, along with tube rolling. I'm liking a 5998 right now.
- Speedball
I'd suggest modifying the headphone plug to a Neitrik rigtht angle plug if you are going to bother with this.
- Replace the headphone jack with a high quality locking Neutrik type
Careful here, you need to know what design parameters determined the composition of each of the original resistor. Resistors in the power supply must have an adequate voltage and power rating, resistors on the PC boards must in some cases be very precise metal film resistors, in other cases once again power and voltage ratings are critical. Grid stoppers may be best if left as carbon composition. Really other than that there aren't that many resistors in the circuit once speedball is in place.
- Replace all resistors with Tantalums or non-inductive film types
You will need to add "make much bigger chassis to hold them. Much bigger." I do however think this might be somewhat audible.
- Replace all capacitors with film types, even on the PSU
This is probably fine. I had heard years ago of Teflon sockets that were getting loose due to cold flow, but I haven't heard that recently.
- Replace sockets with teflon
IME the Goldpoint with Dale resistors sounds best. It might be interesting to try transformer volume controls. Figure on calling up the architect for another addition on that chassis plan.Sometimes it's easier to add another story than to add a room. A very tall box might hold all this extra stuff.
- Replace volume control with DACT or Goldpt
Those little Corcom style things are only for frequencies that are higher than we really need to worry about. Probably better off with a bigger outboard power conditioner that filters down to something like 50kHz. Or you might find just as good a result from putting one of those little Panasonic CMCs and a couple of AC rated caps around 10uF or so at the transformer primary. By now it may just make sense to call a commercial contractor to build your chassis...
- Replace IEC inlet with one that has both filter and fuse
Yeah, if you have converted to XLRs in your system this is a good idea.
- Replace RCA with a Neutrik XLR
The wire is all solid copper as-is.
- Replace cabling with solid silver or solid copper
[/list]
Actually, that is pretty much everything! The joys of DIY!!! Looking forward to first listening!
tdogzthmn said:What are some good stepped attenuators that are reasonably priced and where could I find them. I also wanted to buy a metal knob for the volume control and wanted to know what the shaft dimensions were.
Tom
Doc B. said:eeyore said:Those little Corcom style things are only for frequencies that are higher than we really need to worry about. Probably better off with a bigger outboard power conditioner that filters down to something like 50kHz. Or you might find just as good a result from putting one of those little Panasonic CMCs and a couple of AC rated caps around 10uF or so at the transformer primary. By now it may just make sense to call a commercial contractor to build your chassis...
grufti said:Three resistors and one capacitor will add about $1000 to your Crack on the street. Just kidding, we're not in the drug business here.
You can run this in PSUD II ahead of time to make sure that I am not pulling your leg.
Keep the three 220uf caps, keep the two 270 Ohm resistors in the B+ power supply, add a Panasonic TSED 470uf 250V cap as your fourth cap [one cap], parallel the two existing 270 Ohm 5W resistors with a 360 Ohm 2W resistor each [the combined value for the parallel resistors is something like 154.3 Ohm - this adds 2 resistors], and finally connect the new capacitor that you are adding with a new 150 Ohm 5W resistor [this is the third resistor].
I just finished that change and I'm blown away. Total expense way less than $10.
I measured THD+N before and after. The graphs are too large to attach. Shrinking has to wait until tomorrow. It's late. Try it anyway, this is the biggest gain I've had from any modification in 30+ years of building gear.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
