edward1171
In fact, it's somewhere between 0.003 and 1.7 depending on where on pins 7 and 9 I touch.
I'm at the first "plug it in and make sure you're good to go" stage where you just check for stepped down power at 7 and 9 on the transformer.
It looks like the plastic loop around the base of 9 isn't smooth. Possible heat damage?
Do these come messed up sometimes?
Me causing heat damage is totally a possibility.
I'm reading 120 everywhere else I should be, ground is good, wires are in the proper spots, solder makes solid connections, used two testers (Klein and fluke 15b) and got a friend to check it out just in case I'm missing something.
It's got to be something either in the transformer or with pins 7 or 9 coming out of them.
Can I get a new one?
Or am I overlooking something silly?
I can't upload on android or Mac OS so here's an imgur link
