Hello Bottleheads,
I recently purchased a built-up Crack & Speedball unit from a user on head-fi.org. The Seller touched up the solder joints and verified functionality before sending off. The amp arrived very well-packed, but for whatever reason I am unable to hear sound when the unit is powered on. I am hoping a simple mechanical disturbance occurred in transit but I could use a little help in isolating the issue.
I confirmed proper functioning of source, interconnects, and headphones so I'm pretty sure it's a problem with the unit. Here are the things I have observed:
I am not very experienced with electronics, and nothing obviously visually wrong with the circuit stands out to me. The seller suggested the following:
"Reading through the manual, points 7 & 9 are what connect to b3 and b6, as well as connect to the larger speedball board. So that's something...
The part that gets me though is that power is out on both sides, which is odd because most of the circuit is two independant halves. Even the large speedball board is mostly mirrored across the middle. I find it very unlikely that there would be the same break/damage on both sides at the same spot. A shared path would be the (I think) ground. There's a wire from point 3U to G (page 25 of the speedball manual) that you could double check. I'm not entirely certain if that's a ground path, but it's the only thing I can think of at the moment."
That connection looks good but I am not sure how to confirm on the multi-meter.
Any advice would be greatly appreciated!
Robert B.
- After powering on, tube filaments light up in a seemingly normal fashion
- No LEDs in the circuit are lit when powered on, even after some time.
- During a couple power-up trials, I did notice a very faint, crackly signal in the left channel only if the volume control was maxed or near-maxed. It would fade to nothing in a matter of seconds. I cannot replicate this consistently.
- I went through the resistance checks from the manual and found that terminals 1,5,7,9,b3,b6 are all reading infinite resistance. Other terminals match the manual.
Robert B.
