Good afternoon folks,
I finally have my crack with speedball complete, ran into some issues during the build process that were mainly my fault and I was able to work through (painted wrong side of top plate, miswired the octet socket on initial build, tripped a fuse, had a capacitor leg break during speedball upgrade), and everything is working great now aside from two small issues.
First, there's a very low hum which is present regardless of RCA input and volume knob makes no difference. It's low enough that I don't notice it when music is playing unless it's a very quiet piece and even then it's largely ignorable. My guess is this has something to do with either my mains power or something with my wiring/solder joints.
I went over every joint and made sure it had plenty of solder and wasn't a cold joint, I did this during speedball upgrade as I couldn't get readings off the large board, but I think the capacitors were charged and that caused an issue, eventually was able to get good readings.
Is there any way to test if it's the house mains aside from taking it to another physical location? Or would that require more expensive testing equipment
Secondly, I have some RF interference noise if I use a Genalex Gold Lion ECC82 tube, however If I use the stock RCA tube then I only get the above low hum. tried the same troubleshooting for the noise, it ignores volume knob and RCAs (my first thought was ground loop noise coming from my laptop somehow), but nothing seems to affect it.
While I don't mind using the RCA tube it makes me a little sad I can't really use a tube I paid 30-40 bucks for. Could the tube itself be bad somehow?
Otherwise I'm quite happy with my build so far (and yes I know, mirrored is highly discouraged, but it's working and wired per the manual), need to apply more sealcoat to the wood to get some gloss going, but I'm super stoked with how the stain turned out (picture makes it look more dull than it really is). Paint on the top plate has a couple of blemishes but ah well, I can live with it. Attached some pictures for review, since then I've changed the RCA cables to ones with 90s on one end, looks much cleaner though did nothing really for the sound.
