This is almost always the mounting method of the TIP50C. If improperly mounted, it could cause the problems you're describing at any given time.hpjun said:I thought I did a good job so I turned it on (my mistake for not performing resistance check). none of the boards lighted up and one of the resistors was smoking so I turned it off really quick.
The AC wires that heat the tubes will not cause these kinds of problems unless you remove them and wire them to the incorrect location.
You'll need to carefully measure voltages for us to know what's going on. If you have a smoking 270 Ohm resistor, you could start by measuring the voltages with just the 12AU7 installed in the amplifier and not the 6080.
