Hi there,
After a summer of enjoying my stock Crack, I decided to go for the Speedball upgrade. I gave it a listen after installing the small circuit board and everything sounded superb. Really clean, no background, and great staging. However, once I added the large circuit board, things took a turn for the worse. The mids and bass are distorted, and the background noise (which vanished after the small circuit board install) is back and even louder than before (I think?). Not sure what I messed up.
The Speedball resistance checks passed. With the Speedball voltage checks, I measured 110V at both OA and OB, which is right at the limit of the listed 75-100V +/- 10% values. All LEDs light up on both circuit boards and the 12AU7 tube.
I went back and tried to reflow any joints that looked suspect, and then went back to the original voltage and resistance checks from the Crack manual. All of the voltage checks are within range. Problems are showing up in the resistance checks -- resistance at terminals 7, 9, B3, and B6 is showing as 1 (open circuit) on my DMM (in the manual, each of those should read 2.9K).
I'd really appreciate any suggestions for where to go next. After having that brief glimpse of how amazing the Speedball upgrade can sound, I'm eager to get this working properly.
Many thanks,
Jeff MacInnes
Many thanks,
Jeff MacInnes
