I just moved my good working speedball crack from one room to another. Upon turning on, the headphone output had a faint hum that became loud within a couple of seconds. I turned it off and checked all voltages. They were Okay, but when I checked voltage at the tip of the HP jack, in a few seconds it went to 17vdc then dropped to zero. Repeated and got same results. Any ideas other than possible bad ground? If it is just grounding, where should I reflow?
