Paul Birkeland said:My guess is that your meter don't have a low AC voltage scale? (Maybe it only goes down to 200V?)
100 hours constantly. I do not know why this would be unsafe.takkos said:Do I need to have ~100 hours runtime in the tubes in total, or i have to have it turned on for 100 hours continuously? (It would be a bit unsafety)
See Crack FAQ #3/#4takkos said:One more thing: Is it ok to have music in the right only when I just slightly turn the potentiometer up?
That doesn't have any audible impact on channel balance.takkos said:And the resistance in the RCA pins is different in the left (89,7k) and right (97,7k)
This is rather unlikely.takkos said:I installed two 3A diodes after the ground pin to avoid PC noises, before that i think these numbers were higher.
takkos said:I think that i might got a faulty tube, and the reason why i think this is that the noise only appears after the tube heats up, 10-15-30 seconds after turning on the device.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
