cleaning & painting sides of transformer
jboehle
I got my Crack kit today and the transformer has some goop on the sides that is not so visually attractive.  What can I use to safely clean it off?
Also, is it safe to paint the sides of the transformer?  I would like them to be a glossy black to go with how I am coloring the rest of the amp.
Yes, you can gently sand down the "goop".  Then you can paint the stacks, but mask off the  bell top and terminals bottom.  I use use Rustoleum  Appliance epoxy paint. Works well.
Geary
Caucasian Blackplate said:
The goop is what holds the transformer together, so don't take too much off!
That's why I asked, I didn't want to use some solvent to clean it that would dissolve something important!  Sounds like sanding just the extra goop off the outside should be okay then?  I will tape some plastic over the top & bottom before doing it just so none of it gets inside the transformer.
No solvent.  Just a light sanding to smooth out the varnish.  I just finished a  Crack. The varnish had major runs & globs.  I used a sanding block to get it mostly even without cutting through to the stacks.
Geary
I did mine with a sheet of sandpaper on a pane of glass, the nice flat surface makes it easier to knock off the globs of glue without digging into the laminations. Looks flawless now.
Geary
Hi Geary.
Are you referring to/talking about MY Crack ?
Guy 13
Thanks all, I lightly sanded until smooth to touch, wiped it down with a barely damp rag, then let it dry.  Just finished painting it and now it's drying.  I can still barely see some of the remnants of the goop but hopefully after it dries they will not be noticeable.
Guy 13 said:
Geary
Hi Geary.
Guy 13
That would be the one!
Geary
galyons said:
Guy 13 said:
Geary
Hi Geary.
Guy 13
Geary
Hi Geary.
I should be getting my Crack on April the 11th around 11.30pm,
that the time of arrival of my wife's aunt.
She will also bring with her a 6AS7G RCA with a 12AU7 RCA clear top tunes.
So I will be able to do some tube rolling.
By the time I get back home with the auntie it will probably be around 1.30am,
but I am sure that won't stop me from plug everything and do some listening.
Who knows, I might spen the whole night listening to music.
Guy 13
Sorry for barging in this threat that is not mine.
