ClarityCap SA 100uf 630V film caps on sale
Caps do usually get bigger with larger values. Hard to say why a smaller value is actually larger than a larger value of the same cap, unless the larger value cap is lower voltage rating. Might want to ck that. Not that it really matters, but you may have paid for the 650V and got something lower!
Be careful with the Claritycap wires. I snapped one off trying to straiten it out. Thankfully Madisound replaced it and the new one is on the way.
Paul,
Nope. Both are polypropylene. As far as I can tell, they are identical in construction and specs, except the 0.1uf caps are bigger than the .22uf caps.
And I'll second the warning on the ESA leads. Happened to me with one of my 100uf caps when I was building my Crack. Since the insulation on the lead was intact (making the break invisible), it took me forever to diagnose the problem...
Best regards,
Adam
Funny that you ask that.  The Clarity caps I got were two different labels.  Both say Clarity, but one label is tiny compared to the other.  Here is the picture:
My replacement cap showed up yesterday and both are in and running in my S.E.X.  I had to solder on extension wire to get them to reach!
