blackeyeliner
Here's how it looks:
So I rebuilt the doubler with a new capacitor. It is weird but it's working perfectly when the sound inputs are not connected to the board, the lights go on, doubler produces it's 13.5V DC, but if I connect the sound input, lights on the board (meters illumination) go off and it starts humming into the sound circuit.Caucasian Blackplate said:A terminal strip or a piece of proto board can make that more durable/safe. A 6V winding into a diode bridge will give 4-7V, depending on load and diodes.
blackeyeliner said:Is there something I am terribly missing?
So you think there's nothing I can do on my own at this point? I guess the board design will be hard to get somewhere. It's pretty simple, but I don't understand how connecting audio can make it draw 2+ amperes, really. At the same time, any external power source makes it run perfectly well.Caucasian Blackplate said:Yes, undoubtedly something is very wrong there, but it's hard to know without knowing a lot about the VU board setup.
So it appeared that 12V is not enough for this board to function. It was technically working, but it has a 12V regulator after the diode bridge, that needs 18-19 volts DC to output 12V stabilized. I found a small 24V transformer, put it on a small board, drilled a couple of holes in the casing and here it is, working like a charm. The only problem is that the transformer gets pretty hot.Caucasian Blackplate said:That's probably a better idea. 12V transformers are very easy to find.
They have changed the layout of the board since I bought mine, but it's something like this: http://www.ebay.com/itm/2pcs-Panel-VU-Meter-Warm-Back-Light-Audio-Level-Amp-One-driver-board-/121468037573?pt=LH_DefaultDomain_0&hash=item1c480f29c5mcandmar said:What is the VU board you are using? Most voltage regulators need higher voltage then their output, for example for 7800 series or LM317's they drop out when the source supply is less than 2v above its output voltage so +4v is usually a good target to aim for. Going too high, like feeding a 12v regulator 24v will cause it to run very hot as it has to dissipate the extra voltage.
A hot transformer could indicate the load is higher than the transformers current rating. Generally those small PCB transformers do run hot so its usually a good idea to fit one rated for more current than it needs to supply, assuming you have the physical space.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
