Hi,while i was reading Mr. Joppa's old writings,i noticed something.
" The output tube cathode bypass capacitor (which is on the PSU board) can by bypassed with a film cap across the cathode resistor, T6-T16 and T10-T20. To completely replace the electrolytic, simply remove the wires from T1 and T5 to the PSU board "K" connections.The best place for film bypass capacitors in the power supply would be from the B+ outputs on the PC board, to the nearby cathode resistors at T1 and T5. An extra hole is provided on the PC board for this. "
I read that there are some mistakes in this process.I would like to do this update,but i would like the learn the right procedure. To summarise,the thing that i should do is :
1-Remove the wires from Ks to 16U and 20U.
2-Solder min. 47mf film caps between 16U and Hv+ and 20U and Hv+.
Is this procedure correct? I'll be happy if i get some reply from you.
Thanks.
Thanks.
