Well, with the Orcas, I un-isolated them as they already come isolated -- for those of you with Orcas reading this, just leave yours as they are -- this was just an experiment and the Orcas are already isolated.
Anyway, basically you just need some kind of gasket to isolate the basket of the driver from the cabinet -- each driver willl need some experimentation with which material works best, then you have to place the driver in place on the cabinet and exactly ddrill the screw holes right in the center of the mounting holes on the driver flange -- the idea here is that the screws will not touch the driver and conduct vibration to the cabinet. Then carefully position the drivers in the cabinets and put a small o-ring or bonded washer between the screw head and the driver mounting flange -- now, if done right there are no parts of the driver in direct mechanical contact with the cabinet -- which is the goal.
One other benefit is that by carefully adjusting the torque on the screw heads, it can act as a fine tuning mechanism.
I plan to try this on a friend's zigmahornets once the weather is warm enough to work outside consistently.
And for those who want to know, the drivers on the trishnas appear to be isolated already -- and seeing as the horn tunnels are made of PVC plastic and there is no hint of a plastic sound or unpleasant colorations, my guess is that they did a great job of isolating the driver -- and there also appears to be no damping material, again as with the Orcas.
-- Jim
