I'm eager to try this combination, but can't afford it quite yet. Please report back.joralieu said:Think I will go with the step up and Hana ML, seems to be well liked and is on sale right now. Anyone here using this on their Eros 2?
I didn’t realize the resistors needed to be moved. Is this necessary? If not, what is the advantage? Thanks.Larpy said:Move the 47K load resistors from the input jack tip to ground over to terminals 17/16 and 2/1. (You'll need to solder a short piece of wire between the input ground connection of each input jack to the ground buss.) You want the resistors on the SUT's secondaries rather than on the primaries (which are soldered to the input jack).
We use essential cookies to make this site work, and optional cookies to enhance your experience.
