Cap upgrades for Eros II
You'll be fine Sam. Enjoy the new caps.
In my own Eros i've routed the PCB cable to the bottom . So i'd only need to attach the output cap cable on top mount position.
This helps the ease of changing out capacitors.
denti alligator said:
Last question: is there any reason I can’t attach the leads to the top (instead of bottom) of the terminal strip?
If you attach the caps to the bottom lugs, there's no twisting force on the lugs themselves.  Attached to the top, heavy caps can try to twist the terminals so the rotate within the phenolic, and that can cause some problems down the road.
The leads of these Mundorfs were just too thick too get in the bottom (I had a hard time removing all the solder), so I went with putting them up top.
