Can speaker wire be too thick?
azrockitman
This is only a theoretical question...I have no intention of taking anything to the extreme.....  :o  or do i...... ::)
But seriously, the little bit of understanding I have on the concept suggests to me that in a theoretical instance, you could have cables so thick that a low powered amp couldn't drive the sound.  Is that correct?
Is there an "optimum" gauge or thickness that one should use, for instance with a stereomour?  I'm probably going to go 10 gauge which is not super thick....
Tim
Strictly addressing what you are suggesting, no, thicker wire actually makes it easier for a low powered amp to run a speaker because the resistance per foot goes down as the wire gauge gets fatter. Whether it sounds better is a matter of taste. As a sweeping generality fatter wire tends to have more bass emphasis than skinny wire. But you really have to try it to determine how it works in your specific setup.
I'm probably going to go 10 gauge...
This cracked me up.  Most people use 18 or maybe 16AWG speaker wire.  Audiophiles run the gamut from 30AWG all the way to 5AWG.
Use whatever you like.  Try different kinds.  Avoid shielded speaker wire.
I think the Blumenstein recommended BJC speaker wire is #10.  This is hefty even in my book.
I did once talk about using 4/0 Welding Cable for speaker wire, couldn't find any lugs for it.    ;D
[/quote]
;D  I guess that proves one man's "enough" is another man's too much. (or not enough!)
I'm having difficulty finding 10 gauge locally, so i may try my hand at braiding two or three strands of lesser gauge. Since Bottlehead has already trained me in that fine art..... ;)
Welding cable, huh?  you'd need sunglasses at night for that listening experience.  8)
Or you could just buy some braided cables.  Kimber 4VS is pretty good for the money.
You can get 10 awg belden cable from blue jeans cable for just under a dollar a foot (not affiliated, but I've bought from them more than once). I can't imagine that braiding four lengths of 16 awg cable sourced locally would be too much cheaper. Plus you don't have to braid it.  If you like bragiding cable though, you might as well go all out and do the old venhaus cat5 braided speaker cable.  They will sound different than a speaker cable with a star quad or twisted pair or coax geometry.
You don't want the wire to be a significant part (over 5%) of the total load.  This means that the impedance of the drivers as well as the length of the wire come into play.
Caucasian Blackplate said:
Reap said:
If you really want the best speaker wires...................... http://www.audioquest.com/
That's not particularly helpful/relevant on a DIY website.
Sorry then. But for what it's worth I've bought their wire before and soldered my own ends on it.
This renewed activity here made me get a mental picture of the tiny wire from my Orcas to my Dungeness subs.  But I know it is just signal sensing.  The input impedance should be high enough that there is little to no current, thus no voltage drop.
I post this in case anyone else thinks this needs to be beefier.
