Adrian
I installed the C4S upgrade to my S.E.X. and get 0 to -0.1 VDC at OB and pin B5 instead of 75 VDC.
All of the diodes light well and the valve heaters work.
I checked all other voltages and they are all good with the exception of B6 reading 0.1 VDC vice 2.5 VDC.
I removed the board and connections and thoroughly cleaned the board with Isopropyl alcohol.
I carefully reflowed all solder joints and replaced the twisted pair at IB/OB.
All board components are in the correct position and the transistors are correctly aligned with the 2907A transistor bodies not touching the pads.
I reinstalled the unit and reconnected with the same result: all voltages good with the exception of OB/B5 at about 0 VDC and B6 at about 0 VDC.
I'm not getting anything out of the left channel (OB) - I should be getting the 75 VDC at the plate.
I'm at a loss here. Could I have a damaged transitor? Are there other checks (resistance or voltage) I can take to narrow in on the problem?
