JosephDuffy
Grainger49 said:Watch the solder liquify with the iron against both the PCB trace and the component. After it liquifies hold it for 3s (it is a mental count). This gives me good solder joints every time.
As with most things, I did end up finding that spending more time and slowing down actions helped a lot. I think one of my main issues is when soldering on a board and the blob of solder is a little too large and it makes a sort of "flick" as I move the iron away. I'm assuming these are ok, but it'd be better if I used a little desoldering wick?
I've made sure to get good joints over A5, IA (on the circuit board), but there's still nothing showing when I do a resistance check over A5. Is this expected/safe to turn on/anything else I can be checking to try and find the dodgy joint/component (should one exist)
