PassionForSound
No problems, Paul. Only using the LEDs as an indicator. Happy to focus on voltages now you've told me what to measure. I'll test as soon as I can and report back
These have changed. Can you pull the 12AU7 and recheck?Loquah said:Breg: 157 (A side, now closest to C socket)
Kreg: 1.56 (A side, close to socket C)
Paul Birkeland said:With no 12AU7, are you still seeing that super low voltage at OB on the offending channel?
Loquah said:That was with 6C45Pi installed on both sides.
Confirming measurements WITH 6C45s and WITHOUT 12AU7. All references to sides are based on the A and C sockets on the amp to avoid confusion from the rotated regulator board. Apologies for any redundant info. Just trying to provide a complete picture
+275 = 288
+6.3 = 6.3
IA = 287 (A) 288 (C)
Breg = 285 (A side) 285 (C side)
-reg = 0.3mV (both)
Kreg = 1.16 (A side) 1.02 (B side)
OB: 259 (A) 187 (C)
IB: 285 (both)
IA: 286 (A) 287 (C)
OA: 284 (both)
Paul Birkeland said:OK, so the OB voltage that really wanted to spend the rest of its life at 6V has popped back up without the regulator in the way.
I believe your issue will be resolved by replacing the 431 regulator on the offending channel, with the slightest possibility that you'll also need a 12AU7.
Paul Birkeland said:The amp should tolerated shorted 6C45PI tubes pretty well. Things will heat up if you leave them in there running for a long time though.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
