William Cheng
Hi,
I have posted my question in the email, but I think I will post it here just to gather some advise before I conclude that one of the tube may be faulty.
I have wired up the kit and while checking the individual resistance, I encountered the following two problems.
1. Terminal 30,31,32, H2,H4,H5,H7 : fluctuating between 100 to 200 ohm. Is this resistance value read normal since the manual indicates that it should wander in the tens or hundreds of Kohm.
All other terminals resistance checked are ok.
(Glow test was done successfully at the early stage with both tubes glow).
2. I tried measuring the resistance with the tubes insert and I got the the following reading.
- Terminal 2 : 2.8Kohm
- Terminal 16 : 200Kohm.
(Both values increase volume knob turns)
I tried power up the unit to check the Vdc and I got the following reading.
- Terminal 2 : 3.9Vdc
-Terminal 16 : 96Vdc
I suspect that one of the tube may be faulty, as both resistance and voltage reading at terminal 2 is out. I have swapped the the tubes and I got the opposite reading.
Cheers
Cheers
