Bottlehead C4S as a differential pair constant current sink?
A couple of things:
1.  You shouldn't need/use two separate filament regulators unless heat is an issue.
2.  R3 isn't drawn in the right spot.
3.  The resistor above R3 appears to serve no purpose.
4.  R2 could be a 5K resistor and R1 would be about 142 Ohms.
5.  I would tie the two filaments together, then use a pair of 10 Ohm resistors to make a virtual center tap, then connect the output of the C4S there.  Do note that you may end up needing a hum pot.
6.  The AC balance provided by the C4S will be exceptional!  The DC balance will depend a bit on the tubes themselves, and you may find that transformer performance will improve with matched pairs of tubes.
(and of course, I'd throw in that a single ended circuit with a C4S plate load, parallel feed capacitor, and parallel feed output transformer would be worth building to compare against the differential circuit)
Thanks for reviewing my concept circuit.  I've not used a C4S as a current-sink before, so I wasn't sure about the connections and where the resistors go.  Let me respond to your comments as best I can, and perhaps I'll feel more confident about how  the circuit works.
Response:  Rod Coleman (inventor of Coleman Regulators) advised against running more than one tube per regulator.  He says this results in poor sound from mixing of the plate currents.
Response:  I wasn't sure how to set up a C4S as a current sink.  Where should it go?
Response:  This is a 10-turn, 20 Ohm potentiometer.  Its purpose is to allow for minor balancing of the tubes by adjusting their bias.  The tubes should be matched, but the pot allows for minor tweaking.  If both tubes are perfectly matched this pot would be centered.  If one tube is stronger and passing more current I can adjust the bias to favor the other tube.  Balancing the currents should improve the performance of the transformer.
4.  R2 could be a 5K resistor and R1 would be about 142 Ohms.]
Response:  My schematic has no resistors labeled R1 or R2.  Where should these go?  (and what is the formula for calculating them?)
Response:  A hum-bucking pot would probably require the two filaments to be tied together and be fed by one regulator.  This is advised against.  Anyway, with this regulator there really shouldn't be any hum.  These regulators operate with hum measured in micro-volts.
Response:  I've got quite a stash of #26 tubes and plan to acquire more. :)  I'm hoping to find a matched quad to within a half-mA or better.  I'm sure the tranny will appreciate the effort.  And for parafeed?  Actually, I've got another design I'm working on using chokes and parafeed out.  I still haven't decided which direction I will go.  However, both options have a CCS in the tail, so I need to work out this part of the circuit first.
Question:  If the Rp of each tube is 7400 Ohms, what is the impedance as seen by the transformer in a balanced/push-pull configuration with a CCS in the tail?  Is it just doubled?  (i.e. 14,800 Ohms), or are other factors involved?  There is no kathode resistor (and no bypass cap).  The CCS acts like an almost infinite resistor.  However, since each tube is operating in opposite phase there is no voltage change at their joined kathodes.  With no voltage change, there is no degeneration, and there should be no multiplication by Mu to affect the plate resistance.  At least that is my (crude) understanding.
This is all very tentative in my mind and I'm still reading my books to learn how this works.  I'll need to know the impedance in order to narrow my search for an output transformer.  If you have a clue on how to determine this, I'm all ears.
Thanks again for all the assistance.
That explanation isn't super satisfactory.  In your circuit, the CCS forces balanced AC plate current, the regulators do not control that aspect of the circuit.
The LED's start at ground and then the LED bias resistor is between the second LED and B+.  R4 also goes between the emitter of the 2N2222A and ground. (your transistors are also out of order)
With such low plate current, you'll probably want more adjustment than this.
R1 is generally labeled as the current set resistor on our boards, R2 is the LED biasing resistor.  R1 is approximately 0.855/current.  R2 should bias the LED's with at least 10% of the C4S current, and in your case 1-2mA is OK.
Try loading the tube with a CCS.  Having a CCS under the filaments in a single ended circuit will require a large capacitor across the CCS to function.  The C4S will provide higher impedance than the choke and it won't be susceptible to magnetic noise.
This is a differential circuit, not exactly push-pull. When you setup a gainstage like this, you get half the mu out of each tube and each half of the transformer primary will see a 7.4K source.
I'd be happy to talk about design potentials with you for something like this.  I've build a few differential preamps that don't look that different than what you have on paper, and all of them have been pulled apart and repurposed for other projects.  Doing a single ended parallel feed preamp with the 26 won't be too tough to design and won't be so tough to build either.
Thanks again for the help.  I think the design is coming together.  I've attached a revised schematic that incorporates my understanding of your comments.  I've reversed the transistors and moved the resistors.  This is starting to make more sense to me now.
I'm assuming the LEDs will drop a total of 3 volts so their bias resistor will need to drop 6 volts at 1.5mA (a 4k resistor).  This leaves 10.5mA for the transistors, so the current-set resistor would be 0.855/0.0105 = 81.5 Ohms.  Is my reasoning correct on this?
I added a cap across the whole CCS.  Why is this needed? What is it's purpose?
From my experience running a #26 single-ended, these tubes like to see a load of at least 150 Henrys.  With a 4.5:1 step-down, the reflected impedance from the secondary will be over half a megOhm, so the inductance of the transformer will dominate (as it should).
For a balanced differential circuit, will each plate see only half the Henrys of the entire transformer, or is there some form of inductive coupling between halves of the primary?  As a waveform reaches a crest on one tube it will be reaching a trough for the other tube.  I can almost visualize current passing between each half of the tube pair (like a tennis match) through the coil from one end to the other.  If this visualization is correct, all the Henrys in the primary would be available to load each plate.  If this visualization is incorrect, and all the current comes from the center-tapped B+ connection, then only half the Henries of the entire primary are available to each plate.
I gather that (since you pulled them apart) you were not too happy with the sound?
For the moment, I'm committed to a balanced design.  All my sources are balanced and it seems like a waste to throw away a perfectly good split-phase signal.  One of the signals will be on a 40-foot cable which could easily pick up common-mode noise.  A differential preamp will likely kill most of this.
I intend to tackle this design in two steps.  The first iteration will use 6SN7 tubes.  These are quite linear, cheap and have nearly identical plate resistance to the #26.  They take a bit less current so there would be some resistors to adjust.  The big advantage is a simpler heater supply.  Once I get this working, a conversion to the #26 shouldn't be too difficult.
My C4S kit was purchased more than 10 years ago and I've moved twice since then.  Not much remains from those early days.  I'm quite sure the original LEDs are no longer available.  What LEDs are currently recommended for the C4S circuit?
Thanks for all your thoughtful replies.  This forum is an amazing resource.
I made a bit of a typo earlier.  R2 needs to go to B+, otherwise the resistor and LED string negate the high impedance of the C4S (then you end up with a push-pull circuit after all!).  Take your B+ voltage and divide by 0.002A and you'll get an approximate resistor value, then recalculate your current set resistor for 6mA.
Balanced refers to the cable interface, and when you use an input transformer (which you have drawn into the schematic), then you satisfy the conditions for noise rejection.  There isn't anything about a balanced cable interface that both the hot and cold legs are actually driven by signal.  This is a huge assumption that a lot of modern HiFi manufacturers would like their customers to make, but it simply isn't true.
When you consider the primary of the transformer, it's important to note that the center tap is at AC ground, so one tube will not have the whole primary available to it.
Is your old C4S kit with the off-white PC boards?  The HLMP-6000 is the current LED that meets the requirements for the C4S.
The LED drops about 1.55v each, and the smaller transistor shows about 0.7v base to emitter, leaving 0.855v for the current-set resistor R1.
On the schemo, you have reversed the transistor orientation but have not reversed the rest of the circuit. The base of the 2N2222 goes to the junction of the two LEDs, and the MJE340 base goes to the junction of R2 and the top LED.
There should be no cap across the C4S (from ground to cathodes), and as PB said, R2 should go to the high voltage (I get 70K ohms). Both of these changes are to maintain a high AC impedance at audio frequencies, which is the reason for using a C4S in the first place.
In class A, where both triodes are conducting all the time, the most meaningful inductance at signal frequencies is that of the whole winding as driven by the two triodes in series. The two halves of the primary winding are very tightly coupled and the diff-amp cannot be analyzed as two independent halves.
Ok, I think I've got it.  Please verify the attached schematic.  Here are my responses:
The combined plate resistance of the two triodes in series is about 14.8k.  Based on my understanding of your comment, I would want an output transformer with a total primary inductance of about 300 Henrys.  This would be just over 2.5 times the plate resistance at 20 Hz.  Does that sound about right?
In some cases, I would agree; it depends on the circuit.  A lot of pro audio equipment is balanced and does have signal on both legs.  The signal coming off a phono cartridge is balanced and has signal on both legs.  If my phono preamp uses fully balanced gain stages throughout the circuit, the output (into this preamp) will have signal on both legs.  On the other hand, I've seen many balanced connections that are just cosmetic.
That's a good target to shoot for.
A lot of pro audio equipment (especially a lot of the high dollar vintage gear and copies) have transformer coupled inputs and outputs to provide balanced inputs and outputs.
This is only true if the + and - connections to the cartridge for each channel see equal impedances to ground.  If you connect -L and -R to hard ground at the input of your phono preamp, then you no longer have a balanced cable interface between your cartridge and phono preamp.  If you put a step-up transformer between your MC cartridge and your phono preamp, you can actually add a few switches and resistors to listen to both a balanced and unbalanced cable interface.  I would suggest trying and evaluating this setup.
You have understood my erratic comments on the circuit correctly.  :^)
I'll just add that the notion of primary inductance is pretty fuzzy when you have no airgap in the core. The effective inductance depends on signal level and frequency, and can vary over a very wide range. Usually the manufacturer's spec will indicate a suitable impedance level, i.e. the inductance will be acceptable at that impedance.
