So. I bought my first few old 2A3's for SII (Finally!
These tubes all test +-50-60% on my EICO tester (--> FAIL! :-\ ). Sovteks test 100+.
In the EICO, they do OK, no shorts, no signs of gas *(that last is a simple test of emissions with grid connected to ground vs floating). Now these exhibit blue glow around the internal elements, a very whitish-blue, when cranking the plate voltage a bit.*
They sounded good (Even while "cold" for the short time minute I had the amp on for these pictures)!
Are these safe to use? All have the same results on the tester. Only one pair tested in SII.
Can i try "burning in" these? Any suggested method?
* Edit. I found my EICO to be very conservative on the tube when testing. When in doubt i stress the tube to see how it behaves.
