BeePre sound signature
m17xr2b
Member
Hello, I have a Moon 600i integrated amp and I sometimes use my Quickie instead of the 600i preamp with great results in some cases. For certain types of music I like the added warmth to voices. My plan is to upgrade to the BeePre but only if it will warm/change the sound. I know tubes are a big factor here and I plan to roll some of them but I need to know the base signature for the PreBee. If it's neutral I guess it won't do any good as the 600i preamp should already be neutral and I'm looking to color the sound. If it will sound even better that the 600i preamp that would be a bonus but I'm not holding my breath on it.
BeePre definitely exhibits the weight of the 300B. It's not slow or wooly, but it does have the lower midrange body associated with that tube.
Thank you both, that is what I wanted to hear. The quickie already does an a fine job and I am really intrigued of using a 300B preamp.
I plan to use the Elrog 300B with 8uf Jupiter HT flat-stacked caps. The input of my amp is 26K so 8uf should be fine(hopefully?) as I cannot find the 10uf anywhere for these caps.
Be weary of those Elrogs, they are one of the most microphonics tube out there, especially in the BeePre. I love my pair but they lasted all of three minutes in the BeePre.
I'd say the most impressive aspect of the BeePre is the linear bandwidth of the preamp for a tube design. I get beautiful, real extension of highs and real body in midrange and bass. I think the only drawback as mentioned is microphonics which is somewhat tube dependent, but can be largely defeated by weighting and isolating the tube and chassis. With that now largely controlled, I just love the sound
Thanks, can't wait to start working on it. As I'm on stable 230V using a regenerator is there anything I keep in mind since the beePre is 240V?
You should be just fine with the regenerator.  Bumping to 235V wouldn't hurt anything, but I don't believe that you'll find that necessary.
My regenerator is fixed as 230V. What is the drawback of running it at this voltage? Lower power, less current for the tubes?
While I wait for the kit to arrive I have my custom box ready. I really wanted a glossy finish. Thank you Caucasian Blackplate for the dimensions.
http://imgur.com/yhHXA0g
I have bought a pair of 8uf Jupiter HT flat stack but after reading the manual I'm not sure if I should replace the output or voltage amplifier caps. I got too ahead of myself on this, any help is appreciated.
Also I would like to use some OCC wiring to replace the red and black 9 feet ones. Is 26 gauge enough?
This is my third bottlehead kit and I'm determined to make it the best.
There shouldn't be any.  If the incoming voltage dips too low, noise can become an issue.
The output caps (the ones by the 300B tubes, not the ones at the balanced outputs)
What about the white wire in the kit also?  26 AWG is a little on the low side for certain parts of the kit, and I've also had some experience with the foamed teflon insulation on certain OCCC wire flaking off after 5-ish years.  If you can get 22 AWG, that would be a much better way to go.
I have finished my stock build but I have a couple of weird voltages: D1 has 0.06V and 37 has -0.05.I also measured by mistake D4,D5,D6,D7 with 6.55 but I saw after it's N/A. I also have a slight channel imbalance but also slightly less  voltage on one side for example 10 is 180.1 and 15 is 182.1 but withing the margin of error.
Even so it sounds great and I have to admit better that I expected, the 300B are exactly what I was looking for. I will give a few days to make sure it's stable and then install the BeQuiet, jupiters and elrog.
Could I replace the XLR output with another RCA? Is it as easy as removing the caps and linking the the positive and negative with the existing RCA output? I would like to output to two amps at the same time.
The BeePre certainly does sound amazing, glad to hear that you felt the same as I did when I first started to break it in.  If you're like me, the first 100 hours will be very rewarding.
I also swapped the XLR for a second RCA, as you describe, by directly connecting with output 1 in parallel.
I swapped the 10uF coupling caps to a Jupiter HT Flat Stacked 3.3uF, and I had a mounting bracket 3D printed to hold the cap over the BeeQuiet.  I've been meaning to offer up the model file to the community, but have been too busy listening ;D  See the attached file for an idea of my solution.
Let us know how the Elrog 300b work out.  I've been considering rolling a different 300b; although to be fair, I don't think it's the limiting factor in my system (just cheaper than a VPI Classic/Prime that I've been drooling over, that's for sure  ::)).
Yes, you can, and it is exactly that simple!  I did this in my build - works like a charm.  Wanted a balanced input rather than a balanced output (I biamp, but my downstream amps are both single-ended).  I followed the guide for the balanced inputs, except used the included jacks.  Still looking for input transformers, so that input isn't usable yet, but both outputs work great.
So I have installed the Jupiter caps with some difficulty and I'm now burning the preamp as from experience new gear does sound better with time.
I tried to bypass the integrated preamp of the 600i but there is too much noise and even at the lowest volume setting on the BeeQuiet the volume is quite high(sound not hum). I though I would add some lead rings on the 300B and maybe some inline attenuates to tame the hum but I found something interesting. Even with the BeePre switched off, the power cord, input cables and tubes removed I still get the same hum.Unpluging the output cable kills the hum so there is something related to the BeePre. My first though is that something is acting like an antenna and picking up the hum so I will try to desolder parts of it to try and find out. With the tubes installed if my hand gets close to them without touching the hum is being amplified again with the power cord removed. I switch off the WiFi to rule that out without success. Could I do anything to shield it like adding copper tape inside?
I have remeasured my voltages and C3,D3 were a little off. With the stock EL84 I got 4.29 and 3.59 and with different ones I got 4.9(a little high) and 4.5. I will have to switch tubes to see if the imbalance follows but my gut is telling me it's not the tubes.
Also terminals 1 and 16 were 5.14. Shouldn't it be 5V exactly? My voltage is between 230-240V.
As for the build I am quite please with the results. I have some better knobs incoming to finish it:
http://imgur.com/a/Oqyhc
So I have resoldered everything and even added Dynamat to try and keep vibration to a minimum. Resistances and voltages are within range. I still have a bit of current about 50mV on some terminals that should be 0 like 37. The hum is still present with both EH and Elrog tubes where I cannot use it with the Moon 600i bypassing it's internal preamp. I have tried with a headphone amp and the hum is audible at max volume regardless of the volume on the BeePre. Still my question is why does it hum even when it's off?
I have replaced the Cat5 cables with my own and using a braided copper shield while keeping the drain wire. I also checked all the grounds against the plate to make sure there were no issues there.
To make it usable I built a pair of RCA cables and soldering 20k and 2.2k resistors to  give me about 20db of attenuation. This works well on reducing the hum and I now have a good volume range.
The sound is great but I'm a bit reluctant that I had to resort to that. In case I never find the cause is there any danger for premature failure on the tubes or components because of the hum?
Hum when the unit is off is due to a ground loop or a bad shield in a cable. You will need to experiment with how the AC plugs are configured (use the same outlet for source, preamp and amp - possibly with a ground lift on one piece of gear), cable shielding (make sure the shield is only connected to the outer, signal cold part of the RCA plug at one end of the cable) and possibly with connecting the chassis of your gear together with a wire jumper. Without the equipment in front of me it's difficult to say which approach might be best.
In general it sounds like your amp has a lot of gain, and that you have taken the right approach to improving the noise floor. I'm not sure why adding an attenuator bothers so many users. It's no different than a volume control anywhere else.
I decided to take it one step at a time to try and identify the source of the hum. I have now resoldered everything twice. I tested with three different amplifiers, the BeePre, Quickie and another tube hybrid preamp.
Only the BeePre had about a 20db hum with all three amplifiers and using two different pairs of 300B and three of EL84.
I did further testing where I switched off the power in the house and used my 230V regenerator which has an internal battery to power my dac, beepre and amplifier and this had the same hum. My mains has about 235V so this shouldn't be the issue.
I used both store bought and DIY furutech cables with the shield only at the source end without any difference. There is little to no phone signal in the house and no interference interference as I live in a small village.
The changes I have from stock is: neotech occ 22AWG cable,different power switch, replaced the CAT5 cable with the neotech wire with a braided copper shield, dynamat for vibration dampening. I removed the XLR plugs replacing them with RCA plugs and removing the caps and solder tab. I considered this to be the problem so I put the CAT5 back without any change.
I do have a hum even when the beePre is off and I built something like a faraday cage inside the wood base from fine copper mesh which did fix the hum when it's off but had no effect when it's on.
The resistances all check fine. I do think there might be an error in the manual where A1/B1 and A4/B4 should be reversed. Terminal 1/16 have 4Ω and they are linked with A4/B1 which also has 4Ω but the manual says they should have 5-6Ω.
During my first voltage checks after I just built it I accidentally shorter the 220uF cap at terminals 22,23 for a split second which resulted in a large pop.
Here are my latest voltages:
Terminal  Expected    Actual
1 5V 5.18V
2 90-110V 99V
3 0V 0V
4 9.85V 9.8V
5 0V 7.2mV
6 146V +/0 1% 145V
7 0v fluctuates between 0mV 40mV
8 0v 0V
9 0v 0V
10 186V 177V
11 146V +/- 1% 145V
12 0V fluctuates between -10mV to 10mV
13 0V 0V
14 0V 0V
15 186V 177V
16 5V 5.09V
17 90-110V 95V
18 0V 0V
19 9.85V 9.82V
20 0V 7.2mV
21 0V 0V
22 213V 203V
23 0V 0V
24 0V 0V
25 213V 204V
26 0V 0V
27 0V 0V
28 0V -47mV
29 6.8V 6.45V
30 6.8V 6.45V
31 13.6V 12.95V
32 0V 0V
33 0V 0V
34 13.6V 12.95V
35 6.8V 6.43V
36 6.8V 6.42V
37 0V -53mv
38 0V 0V
39 0V 0V
40 213V 202V
41 0V -9mV
42 0V -9mV
43 213V 202V
44 0V 0V
45 0V 0V
46 213V 203V
47 N/A N/A
48 0V N/A
49 0V N/A
50 N/A N/A
51 0V N/A
A1 Too riskey to probe
A2 90-110V 98V
A3 0V 0V
A4 Too riskey to probe
B1 Too riskey to probe
B2 90-110V 95V
B3 0V 0V
B4 Too riskey to probe
C1,D1 N/A N/A
C2,D2 0V -5.8mV,-8.9mV
C3,D3 3.5-4.5V 5.1V,4.93V
C4,D4 N/A N/A
C5,D5 N/A N/A
C6,D6 N/A N/A
C7,D7 147V 145V,145V
C8,D8 N/A N/A
C9,D9 147V 145V,144V
The thing that jumps out are all those terminals with a few mV on them. I would have assumed if the cap that I shorted was the problem it would have an effect on only once channel but my hum is equal on both sides.
Any advice?
The terminals with a few mV on them are close enough to 0V not to worry about.
Having hum while the preamp is off is concerning, and it's very odd that a Faraday cage would do anything to solve this.  I would be focusing on how tight the hardware is, and looking at all those ground lugs and center lugs on the 5 lug strips that touch the chassis to be sure they are conducting.
We have had a BeePre or two come in that were noisy because of loose hardware.
