Hello all I am a newbie to this gear; this forum sounds like a great resource; before I go any further let me wish you all well in 2015
1. The valve gear (BP and monoblocs) that I purchased last month was purchased and assembled in early 2014.
2. Is this a modification that is needed to upgrade the BP or is it from a specific condition/symptom of the preamp.
3. I have now listened to my 300B s for 30 hours plus the 10 hours of use before my purchase. I have a crackle out of the BP on one side only, I swapped the interconnect at the monobloc and the sound moved to the other speaker so I assumed the BP was the source. I have removed all but my oppo as an input with no change. tube issue?transformer issue? build issue?
My setup currently is the BP , monoblocs, oppo 83( allows me a subwoofer feed), technics 1500( tweeked inhouse) with a Seduction tape amp( low output signal), and a Sony playstation/Thorens 166 mkll depending on what I will listen to . I have a pair of Klipschorn corner speakers for sound delivery.
I did have to add an isolation transformer for the BP because of an original hum, that eliminated the initial hum problem
Any help on the crackling or the value of modification of the input transformer would be appreciated.
I am not a builder/assembler but do appreciate the sound, thanks in advance
[ modified by fullheadofnothing to split out from an unrelated topic, and correct PB to BP ]
